Einleitung
Replacement of an SSR on any Kaffelogic Nano or Nucleus Link coffee roaster with an A, B, C or N prefix serial number.
Was du brauchst
Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
Hold the roaster steady while removing the plastic top/closure.
Remove the 4x 2.5mm Hex screws on the bottom of the roaster.
Stand the roaster up again and pull away the rear panel from the chassis to expose the remaining components.
Disconnect the SSR signal lead and motor from the PCB-A
Remove the 4x PH2 screws securing the gantry plate to the base.
Use a PH2 screwdriver to remove the two mains spade terminals.
Remove the 2x PH2 screws securing the SSR to the bottom of the gantry plate.
