Was du brauchst
Use the kailh style opener.
Press firmly on both sides when lined up correctly.
Be careful to not pop off the protection cover, if it does pop off skip to step 10.
Dip brush in lube.
Use lid of the lube to take off most of the lube on the brush
To preserve tactility only lube the back.
Lube in one or two strokes.
Put all the springs in a bag.
Add the liquid lube and mix it in with the springs
Then put them on a paper towel and separate them.
When putting it together face the bump of the stem towards the green push rod.
Use tweezers to put the green push rod into the position, and then put the protection cover over it.
Eine weitere Person hat diese Anleitung absolviert.
