Einleitung
A Kangen water machine is a handy gadget that provides you with clean, healthful alkaline water. It is critical to replace the water filter on a regular basis in order to maintain water purity and machine efficiency.
To maintain the highest water quality, it is recommended that filters be replaced every 6-12 months. This guide will help you through the process of replacing the water filter in a Kangen Leveluk 8 water machine.
Before beginning make sure to turn off the machine and water supply to avoid water leaks. For an extra precaution unplug the machine.
Was du brauchst
Turn on the machine and select "Setting" at the bottom of the menu.
Select "Filter Check" located towards the bottom of the Settings list; it is the second-to-last option.
If the filter check menu indicates that the filter needs to be replaced, proceed with following steps.
Shut off the water supply to the machine.
Ensure your sink is not running or the filter compartment will leak water during the process.
Push the white arrow up on the left side of the machine to remove the filter compartment cover.
Gently push the locking mechanism in a clockwise direction until it comes out of the slot.
Remove the existing filter from the filter compartment.
Place a cloth underneath the filter compartment to catch any water that may leak during removal.
Align the new filter with the threads inside the filter compartment. Adjust as necessary.
Insert the locking mechanism into the machine by pushing it into the slot on the right side of the filter compartment.
Push the lock in a counter-clockwise direction until reaches the end of the slot.
Close the filter compartment.
Test run the machine with water to ensure it runs properly with the new filter and to see if there are any more errors.
Inspect the filter compartment for any leaks.
The old filter can be disposed of in a garbage bin.
