Einleitung
Use this guide to remove and replace the vacuum motor in a Karcher Carpet Cleaner BRC3015C 2018.
Was du brauchst
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a 3 mm hex key to remove the four bolts securing the pump cover.
Use a flathead screwdriver to loosen the hose clamp securing the flexible hose to the vacuum motor.
Use a Phillips #2 screwdriver to remove the three screws securing the vacuum motor cover to the vacuum motor.
Use a Phillips #2 screwdriver to remove the two screws securing the fan cover.
Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the vacuum motor.
Use a pair of flush cutters to cut all the zip-ties securing any wires to the vacuum motor.
Use a pick or small flathead screwdriver to push down on the tab securing one of the motor's power cable connectors while gently sliding the connector out of its slot.
Use a zip tie, or anything flat and roughly the size of the spade connector, to slide into the slot as you slide the spade connector out of the slot.
Repeat the last two steps to remove the other power cable on the vacuum motor.
Your new vacuum motor may not come with a vibration damping pad already installed. If so, carefully peel the pad off the old motor and transfer it to the new motor.
