Zum Hauptinhalt wechseln
Katadyne Hiker Water Filter Cleaning
Was du brauchst
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: Schritt 1, Bild 1 von 1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: Schritt 2, Bild 1 von 1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: Schritt 3, Bild 1 von 3 Katadyne Hiker Water Filter Cleaning: Schritt 3, Bild 2 von 3 Katadyne Hiker Water Filter Cleaning: Schritt 3, Bild 3 von 3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: Schritt 4, Bild 1 von 3 Katadyne Hiker Water Filter Cleaning: Schritt 4, Bild 2 von 3 Katadyne Hiker Water Filter Cleaning: Schritt 4, Bild 3 von 3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: Schritt 5, Bild 1 von 1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: Schritt 6, Bild 1 von 1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: Schritt 7, Bild 1 von 1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: Schritt 8, Bild 1 von 2 Katadyne Hiker Water Filter Cleaning: Schritt 8, Bild 2 von 2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Abschluss
If difficulty pumping persists, a new filter is required.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dylan Carey
130 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-6, Green Winter 2015 Mitglied von Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 713
