Einleitung
Use this guide to replace a worn drive belt in a Kenmore 110 Series Washing Machine.
Was du brauchst
Using a 5/16" socket wrench, remove both screws from the belt cover.
Remove the belt cover from the washer.
Using a 1/2" socket, remove the bolt securing the drive pulley.
Remove the drive pulley and belt.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
What would be reason that rinse cycle doesn't spin and it leaks
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
It makes noise like it’s working but it’s not grabbing anything
You can change your gearbox
What belt type should I use for a 110.24642300? I cannot find its belt online.
