Zum Hauptinhalt wechseln
Kenmore 110 Series Washing Machine Electronic Control Replacement
Was du brauchst
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: Schritt 1, Bild 1 von 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: Schritt 2, Bild 1 von 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: Schritt 2, Bild 2 von 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: Schritt 2, Bild 3 von 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: Schritt 3, Bild 1 von 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Robert Trout
1.234 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 15-43, Forte Fall 2012 Mitglied von Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Mitglieder
12 Anleitungen geschrieben
3 Kommentare zur Anleitung
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Antwort
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 132
Insgesamt: 30,605
