Einleitung
Use this guide to replace a faulty lid switch on your Kenmore 110 series washing machine.
Was du brauchst
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
Set the top panel on its rear face, with its underside facing you.
Using a 5/16" socket wrench or hand wrench, remove the two screws from the component cover.
Gripping from the bottom, pull the component cover out of the washer.
Carefully unplug the two wires connected to the lid switch.
Remove the two Phillips screws securing the bracket.
Remove the green ground wire.
With a screwdriver, remove the single screw connecting the lid switch to the bracket.
9 weitere Personen haben diese Anleitung absolviert.
14 Kommentare
my model # 11088732796 is not the same as yours
No it ia neither of those. Thank for the reply though. My washer is a 90 series.
Lol I found the solution on YouTube. All it takes is a zip tie because the lid switch for he 90s series Kenmore washer is two half pieces glued together
my Kenmore washer model# is 110.24812200; series CP2654205. Cannot remove top to repair lid switch following your video! removed the three screwsf from the back but cannot get control panal to come off! Please reply soon.
