Zum Hauptinhalt wechseln
Kenmore 110 Series Washing Machine Water Pump Replacement
Was du brauchst
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: Schritt 1, Bild 1 von 1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: Schritt 2, Bild 1 von 3 Kenmore 110 Series Washing Machine Water Pump Replacement: Schritt 2, Bild 2 von 3 Kenmore 110 Series Washing Machine Water Pump Replacement: Schritt 2, Bild 3 von 3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
Abschluss
14 weitere Personen haben diese Anleitung absolviert.
Robert Trout
1.234 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 15-43, Forte Fall 2012 Mitglied von Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Mitglieder
12 Anleitungen geschrieben
9 Kommentare zur Anleitung
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Antwort
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Antwort
My clothes are still really wet.
Tracy Schultz - Antwort
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 57
Letzte 30 Tage: 232
Insgesamt: 64,080
