Zum Hauptinhalt wechseln
Kenmore 78423 Dustbin fiber collector Replacement
  1. Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: Schritt 1, Bild 1 von 2 Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: Schritt 1, Bild 2 von 2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin fiber collector Replacement: Schritt 2, Bild 1 von 2 Kenmore 78423 Dustbin fiber collector Replacement: Schritt 2, Bild 2 von 2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: Schritt 3, Bild 1 von 3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: Schritt 3, Bild 2 von 3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: Schritt 3, Bild 3 von 3
    • Grab the fiber collector using the finger holes on both sides of the base.
    • The fiber collector is the black basket with the rounded base
    • Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Remove the fiber and hair that may be stuck inside the fiber collector
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Fullerton, Team S2-G4, Bruce Fall 2018 Mitglied von CSU Fullerton, Team S2-G4, Bruce Fall 2018
CSUF-BRUCE-F18S2G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
joseph doyle - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 491
