Einleitung
Here we have a Kenmore 90 Series that will not start its spin cycle. This occurs when the motor coupler connected to the drive motor has been worn over time. In this guide, you will will learn the step-by-step process of replacing this component. Prior to beginning your repair, be sure to unplug the washing machine.
Was du brauchst
Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
Stand in front of the washer and remove the chassis by lifting and pulling it towards you to expose the lower components.
Use the flat head screwdriver to flip the restraining clips and release the drain pump.
Place the drive motor to the side and remove the direct drive coupler by sliding it off.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
