Zum Hauptinhalt wechseln
Was du brauchst
  1. Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: Schritt 1, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: Schritt 1, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: Schritt 1, Bild 3 von 3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Headband: Schritt 2, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 2, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 2, Bild 3 von 3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Headband: Schritt 3, Bild 1 von 2 Kensington Hi-Fi Headphones 33137 Headband: Schritt 3, Bild 2 von 2
    • This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
    • Turn the headphones so that the inner headphone cover is visible.
  4. Kensington Hi-Fi Headphones 33137 Headband: Schritt 4, Bild 1 von 2 Kensington Hi-Fi Headphones 33137 Headband: Schritt 4, Bild 2 von 2
    • Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
    • The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • All steps can be followed on both the left or right side of the headphones to remove inner coverings.
  5. Kensington Hi-Fi Headphones 33137 Headband: Schritt 5, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 5, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 5, Bild 3 von 3
    • Use the screwdriver to pry the inner headband covering loose.
    • Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
    • Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
  6. Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: Schritt 6, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: Schritt 6, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: Schritt 6, Bild 3 von 3
    • Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
    • Pull the speaker clamp so that the metal lifts free of the headband.
  7. Kensington Hi-Fi Headphones 33137 Headband: Schritt 7, Bild 1 von 1
    • Remove the speaker clamp.
    • All steps can be followed on either the left or right arm of the headphones to remove speaker clamps.
  8. Kensington Hi-Fi Headphones 33137 Headband, Headband Adjustment Piece: Schritt 8, Bild 1 von 2 Kensington Hi-Fi Headphones 33137 Headband, Headband Adjustment Piece: Schritt 8, Bild 2 von 2
    • Turn the headphones so that the metal pieces inside the headband covering can be seen.
  9. Kensington Hi-Fi Headphones 33137 Headband: Schritt 9, Bild 1 von 2 Kensington Hi-Fi Headphones 33137 Headband: Schritt 9, Bild 2 von 2
    • With your fingers, lift the small metal headband adjustment piece.
    • Remove the piece and set it aside.
    • All steps can be followed on either the left or right arm of the headphones to remove adjustment pieces.
  10. Kensington Hi-Fi Headphones 33137 Headband, Headband: Schritt 10, Bild 1 von 2 Kensington Hi-Fi Headphones 33137 Headband, Headband: Schritt 10, Bild 2 von 2
    • Turn the headphones so that the metal part of the headband located inside the outer covering can be seen.
  11. Kensington Hi-Fi Headphones 33137 Headband: Schritt 11, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 11, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Headband: Schritt 11, Bild 3 von 3
    • With your fingers, pull the metal arm of the headband free of the plastic outer covering.
    • Set the outer covering aside.
  12. Kensington Hi-Fi Headphones 33137 Headband: Schritt 12, Bild 1 von 1
    • All steps must be followed on both the left and right arms of the headband to free it completely from the outer coverings.
Abschluss
Alexis Carr
417 Reputation
4 Anleitungen geschrieben
Clemson, Team 1-3, Benson Spring 2014 Mitglied von Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Do you know how to make an adjustable headband for custom headphones? Please contact me!
Lisa Campbell
Owner Lit Headphones L.L.C.
LitHeadphones.com
MsLisaShawnitaCampbell@gmail.com
Lisa Campbell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 477
