Einleitung
The headband on the Kensington Hi-Fi Headphones 33137 may occasionally become uncomfortable or worn and need replacement. This guide shows how to replace this component.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover. Do not pull out the speaker clamp with too much force, or it may break. After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Repeat the process in Step 1 to remove the right speaker clamp. Repeat the process in Step 1 to remove the right speaker clamp. Repeat the process in Step 1 to remove the right speaker clamp.
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier. Turn the headphones so that the inner headphone cover is visible.
    • This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
    • Turn the headphones so that the inner headphone cover is visible.
  4. Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place. The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
    • The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • All steps can be followed on both the left or right side of the headphones to remove inner coverings.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Use the screwdriver to pry the inner headband covering loose. Do not push the inner covering panel too hard, or the plastic will break.  Only apply enough pressure to lift the panel up slightly. Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Use the screwdriver to pry the inner headband covering loose.
    • Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
    • Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
  7. Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen. Pull the speaker clamp so that the metal lifts free of the headband. Pull the speaker clamp so that the metal lifts free of the headband.
    • Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
    • Pull the speaker clamp so that the metal lifts free of the headband.
  8. Remove the speaker clamp.
    • Remove the speaker clamp.
    • All steps can be followed on either the left or right arm of the headphones to remove speaker clamps.
  9. Turn the headphones so that the metal pieces inside the headband covering can be seen. Turn the headphones so that the metal pieces inside the headband covering can be seen.
    • Turn the headphones so that the metal pieces inside the headband covering can be seen.
  10. With your fingers, lift the small metal headband adjustment piece. Remove the piece and set it aside.
    • With your fingers, lift the small metal headband adjustment piece.
    • Remove the piece and set it aside.
    • All steps can be followed on either the left or right arm of the headphones to remove adjustment pieces.
  11. Turn the headphones so that the metal part of the headband located inside the outer covering can be seen. Turn the headphones so that the metal part of the headband located inside the outer covering can be seen.
    • Turn the headphones so that the metal part of the headband located inside the outer covering can be seen.
  12. With your fingers, pull the metal arm of the headband free of the plastic outer covering. Set the outer covering aside. Set the outer covering aside.
    • With your fingers, pull the metal arm of the headband free of the plastic outer covering.
    • Set the outer covering aside.
  13. All steps must be followed on both the left and right arms of the headband to free it completely from the outer coverings.
    • All steps must be followed on both the left and right arms of the headband to free it completely from the outer coverings.
Abschluss
Alexis Carr
417 Reputation
4 Anleitungen geschrieben
Clemson, Team 1-3, Benson Spring 2014 Mitglied von Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Mitglieder
9 Anleitungen geschrieben
Do you know how to make an adjustable headband for custom headphones? Please contact me!
Lisa Campbell
Owner Lit Headphones L.L.C.
LitHeadphones.com
MsLisaShawnitaCampbell@gmail.com
Lisa Campbell - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 333
