Zum Hauptinhalt wechseln
Kensington Hi-Fi Headphones 33137 Speakers
Was du brauchst
  1. Kensington Hi-Fi Headphones 33137 Speakers, Speaker Cover: Schritt 1, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Speakers, Speaker Cover: Schritt 1, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Speakers, Speaker Cover: Schritt 1, Bild 3 von 3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Speakers: Schritt 2, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Speakers: Schritt 2, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Speakers: Schritt 2, Bild 3 von 3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Speakers: Schritt 3, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Speakers: Schritt 3, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Speakers: Schritt 3, Bild 3 von 3
    • Hold the speaker cover in one hand and the speaker ear-padding in the other.
    • Turn the speaker cover counter-clockwise until it stops turning.
    • Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
    • Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
    • If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
    • Repeat this process for both speakers.
  4. Kensington Hi-Fi Headphones 33137 Speakers, Speakers: Schritt 4, Bild 1 von 3 Kensington Hi-Fi Headphones 33137 Speakers, Speakers: Schritt 4, Bild 2 von 3 Kensington Hi-Fi Headphones 33137 Speakers, Speakers: Schritt 4, Bild 3 von 3
    • With the internal speaker component exposed, the wires connecting the speakers to the speaker cable can be cut.
    • Reassembly after cutting the speaker cable wires will require soldering. Proceed with caution. See Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
    • Cut each of the wires connecting the speaker to the speaker cable.
    • Repeat this process for each speaker.
Abschluss
To reassemble your device, follow the instructions in the Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Clemson, Team 1-3, Benson Spring 2014 Mitglied von Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 507
