Zum Hauptinhalt wechseln
Kenwood DNX571HD CD/DVD Drive Replacement
Was du brauchst
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: Schritt 1, Bild 1 von 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: Schritt 1, Bild 2 von 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 2, Bild 1 von 3 Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 2, Bild 2 von 3 Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 3, Bild 1 von 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 4, Bild 1 von 3 Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 4, Bild 2 von 3 Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 6, Bild 1 von 2 Kenwood DNX571HD CD/DVD Drive Replacement: Schritt 6, Bild 2 von 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Wendy Zaballos
952 Reputation
6 Anleitungen geschrieben
Washington State, Team S1-G1, Hope Fall 2018 Mitglied von Washington State, Team S1-G1, Hope Fall 2018
WSU-HOPE-F18S1G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,107
