Einleitung
If your Kenwood DNX571HD car stereo is having difficulties connecting to satellite radio, the antenna connection may be faulty. Replace it with this guide.
Was du brauchst
Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Carefully unplug the fan power cord with the tweezers.
Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
Remove the metal plate
Remove the four 5mm screws from the corners of the circuit board using a Phillips #1 screwdriver
Lift the circuit board from the rest of the assembly.
