Zum Hauptinhalt wechseln
Kenwood DRV-N520 Dashcam Motherboard Replacement
Was du brauchst
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 3, Bild 1 von 2 Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 4, Bild 1 von 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 4, Bild 2 von 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
Abschluss
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Ein Kommentar
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 215
