Zum Hauptinhalt wechseln
Kenwood DRV-N520 Dashcam Speaker Replacement
Was du brauchst
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 2, Bild 1 von 3 Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 2, Bild 2 von 3 Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 3, Bild 1 von 2 Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 3, Bild 2 von 2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 4, Bild 1 von 2 Kenwood DRV-N520 Dashcam Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
Abschluss
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
136 Reputation
1 Anleitung geschrieben
ERAU-LAMOTHE-S20S14G1 Mitglied von ERAU-LAMOTHE-S20S14G1
Repair Café
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 146
