Zum Hauptinhalt wechseln
Kenwood KDC-BT362U DVD-Drive Replacement
Was du brauchst
  1. Kenwood KDC-BT362U DVD-Drive Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 2, Bild 1 von 2 Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 2, Bild 2 von 2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 3, Bild 1 von 2 Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 3, Bild 2 von 2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 4, Bild 1 von 2 Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the front panel.
  6. Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: Schritt 6, Bild 1 von 3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: Schritt 6, Bild 2 von 3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: Schritt 6, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
  7. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 7, Bild 1 von 3 Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 7, Bild 2 von 3 Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 7, Bild 3 von 3
    • Carefully separate the top and bottom halves of the metal case apart.
    • Do not separate the metal case halves completely.
    • Carefully pull the DVD-Drive ribbon cable from the motherboard.
  8. Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: Schritt 8, Bild 1 von 2 Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: Schritt 8, Bild 2 von 2
    • Use the Phillips #0 Screwdriver to remove the three screws.
  9. Kenwood KDC-BT362U DVD-Drive Replacement: Schritt 9, Bild 1 von 1
    • Lift the DVD-Drive to separate it from the metal case.
Abschluss
Steven Chov
349 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 2-5, Cagle Fall 2016 Mitglied von USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 476
