Was du brauchst
Starting on the top side, pop the front panel frame out.
Remove the face-plate frame.
Use the plastic opening tool to pry open the tabs.
Repeat on the opposite side.
Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
Carefully separate the top and bottom halves of the metal case apart.
Carefully pull the DVD-Drive ribbon cable from the motherboard.
Fast fertig!
Abschluss
