Einleitung
Replacing the Puncture Needle is similar to the Handle Replacement, but requires a couple extra steps outlined below.
Was du brauchst
Locate and remove the two 9.5 mm Phillips #1 screws.
Remove the plastic ring around the K-Cup Pack Holder
Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
Squeeze and pull on the hose to remove it from the Puncture Needle
Puncture needle should now be exposed
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I will be completing this guide but where do you get the replacement puncture needles for this model??
John Lawson
