Einleitung
Replacing the Water Filter requires only a couple steps as outlined below.
Was du brauchst
Remove the Water Reservoir Cap and the Water Reservoir from the brewer by simply pulling up and out
Remove the three 9.5 mm Phillips #1 screws that secure the small circular screen to the bottom of the water reservoir.
This circular screen has a rubber "O"-ring around the base. Use the plastic opening tool to pry off the rubber seal. Replace with undamaged seal.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
