Einleitung
Cracked base? Or maybe you feel like taking it out for a thorough wash?
This guide will show you how to remove the plastic base surrounding the Keurig B70 Platinum device.
You will need a Phillips #2 screwdriver to complete this guide.
Was du brauchst
Turn off and unplug the Keurig before starting.
Turn the Keurig upside down so the metal base is exposed.
Remove the five 12.0 mm screws.
Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
Pull out the red and white wires and put it off to the side of the Keurig.
Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
Lift the metal base and hover it over the opening of the black plastic base.
Carefully raise the plastic base over the metal base until it is removed.
