Einleitung
Is your Keurig slow to brew or leaking water? This quick fix might be your answer to get you right back to brewing. This guide will show you how to easily replace your check valve in the Keurig B70 Platinum. The check valve is located at the top of the machine and can cause slow brewing or water not coming out of your machine if it is clogged or damaged.
Before continuing, make sure you unplug your machine and have a Phillips screwdriver and a pair of scissors handy.
Was du brauchst
Lift up the top lid.
Remove the two screws with a Phillips #0 screwdriver.
Using the Phillips #0 screwdriver, remove the two screws holding the tubing to the puncture needle.
Reassemble the valve in place.
Resecure it with a zip tie.
Trim the excess plastic off of the zip tie.
Eine weitere Person hat diese Anleitung absolviert.
