Einleitung
If your puncture needle is damaged or dulled, follow this guide to safely remove and replace the puncture needle. The puncture needle is sharp so try to only touch the plastic holding the puncture needle. To complete the replacement, you will need a T15 Torx screwdriver, a Phillips #0 screwdriver, and a Phillips #2 screwdriver.
Was du brauchst
Turn off and unplug the Keurig before starting.
Lay the Keurig on its back and open the lid.
Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
Using a Phillips #0 screwdriver, remove the two 7.0 mm screws located on the sides of the tube near the puncture needle.
Using both hands, pull the puncture needle tube and the Keurig tube apart to disconnect the tubes.
Slide the black plastic ring, which holds the puncture needle tube down, off of the tube.
Using a Phillips #2 screwdriver, remove the two 9.0 mm screws next to the detached tube.
