Einleitung
Clogged filter?
This guide will show you how to remove the water filter found inside the Keurig B70 Platinum water reservoir.
You will only need a Phillips #2 screwdriver for this guide.
Was du brauchst
Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
Remove the three 11.0 mm screws from the reservoir filter.
4 Kommentare
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
