Zum Hauptinhalt wechseln
Keurig K10 MINI PLUS Dispenser Head Replacement
Was du brauchst
  1. Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Lid: Schritt 1, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Lid: Schritt 1, Bild 2 von 2
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 2, Bild 1 von 1
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Keurig K10 MINI PLUS Dispenser Head Replacement, Top Needle: Schritt 3, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Top Needle: Schritt 3, Bild 2 von 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 4, Bild 1 von 3 Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 4, Bild 2 von 3 Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 4, Bild 3 von 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 5, Bild 1 von 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  6. Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: Schritt 6, Bild 1 von 3 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: Schritt 6, Bild 2 von 3 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: Schritt 6, Bild 3 von 3
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  7. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 7, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 7, Bild 2 von 2
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  8. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 8, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 8, Bild 2 von 2
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
  9. Keurig K10 MINI PLUS Dispenser Head Replacement, Dispenser Head: Schritt 9, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Dispenser Head: Schritt 9, Bild 2 von 2
    • Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
    • There is a spring concealed by a white piece as shown.
  10. Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 10, Bild 1 von 2 Keurig K10 MINI PLUS Dispenser Head Replacement: Schritt 10, Bild 2 von 2
    • Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
Abschluss
Matt Bav
577 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G7
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 960
