Einleitung
In this guide we will show you how to successfully remove the handle from the K-cup.
Was du brauchst
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Once you remove the screws, the top cover should come out.
You will then want to remove these screws which are the same size.
Once you get those removed, you are going to want to pull on the hose until it pops off.
Once the hose comes off, the needle will fall out by itself.
Next, after the removal of the hose on the top by simply pulling it off, remove the following four Phillips #1 screws.
To pull this part off, pull inwards with the these tabs located on both sides of the handle assembly.
Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
