Zum Hauptinhalt wechseln
Keurig K10 MINI PLUS Top Needle Replacement
Was du brauchst
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: Schritt 1, Bild 1 von 3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: Schritt 1, Bild 2 von 3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: Schritt 1, Bild 3 von 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: Schritt 2, Bild 1 von 2 Keurig K10 MINI PLUS Top Needle Replacement: Schritt 2, Bild 2 von 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: Schritt 3, Bild 1 von 2 Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: Schritt 3, Bild 2 von 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: Schritt 4, Bild 1 von 3 Keurig K10 MINI PLUS Top Needle Replacement: Schritt 4, Bild 2 von 3 Keurig K10 MINI PLUS Top Needle Replacement: Schritt 4, Bild 3 von 3
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: Schritt 5, Bild 1 von 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Mark Henein
369 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 17-6, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Mitglieder
Ein Kommentar
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 5,205
