Zum Hauptinhalt wechseln
Keurig K10 Mini Plus Cup Holder Replacement
Was du brauchst
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: Schritt 1, Bild 1 von 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: Schritt 1, Bild 2 von 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: Schritt 1, Bild 3 von 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: Schritt 2, Bild 1 von 2 Keurig K10 Mini Plus Cup Holder Replacement: Schritt 2, Bild 2 von 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Abschluss
Mark Henein
369 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 17-6, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Mitglieder
Ein Kommentar
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,493
