Einleitung
This guide will show an individual how to replace the water filter in the Keurig K40. This will require access to a screwdriver.
Was du brauchst
Flip the device on its side so that the metal faces you.
Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
Pull the pump back to remove it from the slot it was in.
Grip where the filter and the flow line connect and pull apart until they are separated.
Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
12 weitere Personen haben diese Anleitung absolviert.
13 Kommentare
Where do you obtain a new filter?
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
I need the filter, where do I buy a new Filter?
