Zum Hauptinhalt wechseln
Keurig K40 Bottom Water Filter Replacement
Was du brauchst
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: Schritt 1, Bild 1 von 2 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: Schritt 1, Bild 2 von 2
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: Schritt 2, Bild 1 von 2 Keurig K40 Bottom Water Filter Replacement: Schritt 2, Bild 2 von 2
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: Schritt 3, Bild 1 von 2 Keurig K40 Bottom Water Filter Replacement: Schritt 3, Bild 2 von 2
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: Schritt 4, Bild 1 von 1
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
jonathan
738 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-1, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Mitglieder
5 Anleitungen geschrieben
13 Kommentare
Where do you obtain a new filter?
Anthony Montoya - Antwort
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - Antwort
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - Antwort
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - Antwort
The answer seems to be: “You don’t.”
Van Davis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 36
Letzte 30 Tage: 133
Insgesamt: 34,785
