Einleitung
This guide will demonstrate how to open the top unit of the Keurig K40. It will also demonstrate how to remove and replace the top water pump from a Keurig K40 device.
Was du brauchst
Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
The water pump and pipe should now be loose and easy to move as shown.
Pull on the point where the pipe meets the water pump.
The pipe will come loose and the water filter will be free and ready to be replaced.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
