Zum Hauptinhalt wechseln
Einleitung
Removal and replacement of the Keurig K55 water filter.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Grab the lid of the water reservoir on the left side of the Keurig. Lift up to remove the water reservoir lid. Lift up to remove the water reservoir lid.
    • Grab the lid of the water reservoir on the left side of the Keurig.
    • Lift up to remove the water reservoir lid.
  2. Grab the water filter on the inside of the reservoir. Remove filter by pulling straight up.
    • Grab the water filter on the inside of the reservoir.
    • Remove filter by pulling straight up.
    • Pulling the filter out may require a bit of effort.
  3. Pinch both sides of end cap on the large end of the filter. With both tabs compressed, pull the cap off of the housing. With both tabs compressed, pull the cap off of the housing.
    • Pinch both sides of end cap on the large end of the filter.
    • With both tabs compressed, pull the cap off of the housing.
  4. Remove exposed filter. Remove exposed filter.
    • Remove exposed filter.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
William O'Brien
500 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S1-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 28
Letzten 30 Tage: 87
Insgesamt: 7,872
