Einleitung
If your Keurig K70 does not close properly you may need to replace the handle. This guide will walk you through the necessary steps to do so. It is an easy fix but requires an uncommon tool.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Locate the handle on top of the unit
Locate the two Torx head screws on the underside of the handle. Remove them with a T15 screwdriver
Fast fertig!
Abschluss
