Einleitung
Regular usage of this device may cause the K-cup holder to clog or accidentally crack. This guide will show you how to remove a K-cup holder for either cleaning or replacement for your Keurig Mini B-31.
Was du brauchst
Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
See here for k-cup holder removal.
