Was du brauchst
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Gently detach the first clip from the bar with the ON / OFF button.
Gently detach the second clip from the bar with the ON / OFF button.
And so on.
Flip the laptop over and then untap this bar
The four screws that moor the keyboard will appear.
Now unscrew these four screws.
Now gently release the keyboard.
Then reverse it.
Release now by helping you with a screwdriver the keyboard cable.
To reassemble your device follow the following instructions in reverse order
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
