Zum Hauptinhalt wechseln
Kid Galaxy Morphibians Explorer Axle Replacement
Was du brauchst
  1. Kid Galaxy Morphibians Explorer Axle Replacement, Axle: Schritt 1, Bild 1 von 1
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Kid Galaxy Morphibians Explorer Axle Replacement: Schritt 2, Bild 1 von 1
    • Remove the wheels by pulling them away from the RC car.
  3. Kid Galaxy Morphibians Explorer Axle Replacement: Schritt 3, Bild 1 von 1
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Kid Galaxy Morphibians Explorer Axle Replacement: Schritt 4, Bild 1 von 1
    • Pry open the two gear covers on both sides.
  5. Kid Galaxy Morphibians Explorer Axle Replacement: Schritt 5, Bild 1 von 1
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Kid Galaxy Morphibians Explorer Axle Replacement: Schritt 6, Bild 1 von 1
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Abschluss
USF Tampa, Team 1-2, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 269
