Einleitung
There are only a few steps that you need to take in order to replace the batteries.
Was du brauchst
First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
Lift the battery cover to gain access to the batteries.
Replace the 3 AA batteries and reverse the steps to put everything back together.
