Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn the controller over to the backside and locate the battery cover screw.
    • Turn the controller over to the backside and locate the battery cover screw.
  2. The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Once the screw is removed lift the battery cover up from the controller.
    • Once the screw is removed lift the battery cover up from the controller.
  4. Remove the 2 AA batteries.
    • Remove the 2 AA batteries.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
    • Remove both the 6.0mm Phillips #1 screws holding the D-pads in place.
  7. Insert wisdom here.
    • Insert wisdom here.
  8. Remove the four  8.1 Phillips #1 screws (red:) and (orange:)
    • Remove the four 8.1 Phillips #1 screws (red:) and (orange:)
  9. Lift the antenna holder away from the controller towards the top of the antenna.
    • Lift the antenna holder away from the controller towards the top of the antenna.
  10. Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  11. Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  12. Remove the internal chip by pulling it away from the controller.
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
Abschluss
Rusbell Gonzalez
219 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-2, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 110
