Zum Hauptinhalt wechseln
Kids Digital Watch Battery Replacement
Was du brauchst
  1. Kids Digital Watch Battery Replacement, Remove Watch Bands: Schritt 1, Bild 1 von 2 Kids Digital Watch Battery Replacement, Remove Watch Bands: Schritt 1, Bild 2 von 2
    • Using a twisting and pulling motion, remove the straps from the watch.
  2. Kids Digital Watch Battery Replacement, Unscrew Backplate: Schritt 2, Bild 1 von 1
    • Remove the four (4) screws on the backside of the watch with the small Philips head screwdriver.
  3. Kids Digital Watch Battery Replacement, Remove Backplate: Schritt 3, Bild 1 von 1
    • Remove the backplate carefully using your hands.
  4. Kids Digital Watch Battery Replacement, Remove Circuit Protector Plate: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove using tweezers the circuit protector plate that is uncovered once the backplate is removed.
  5. Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: Schritt 5, Bild 1 von 2 Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: Schritt 5, Bild 2 von 2
    • With the tiny Philips head screwdriver, unscrew and remove the screw closest to the blue component.
  6. Kids Digital Watch Battery Replacement, Removing Screw Near the Yellow Component: Schritt 6, Bild 1 von 1
    • Now remove the screw on the other side of the battery near the yellow circuit component.
  7. Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: Schritt 7, Bild 1 von 2 Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: Schritt 7, Bild 2 von 2
    • Using tweezers carefully remove the battery protector plate.
  8. Kids Digital Watch Battery Replacement, Remove Battery: Schritt 8, Bild 1 von 1
    • Remove the old battery from your watch.
  9. Kids Digital Watch Battery Replacement, Insert New Battery: Schritt 9, Bild 1 von 1
    • Insert your new battery onto the circular component with your tweezers.
    • Ensure the positive and negative sides of your battery are oriented correctly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Amelia S
194 Reputation
1 Anleitung geschrieben
ENGR_COMM_FIXERS Mitglied von ENGR_COMM_FIXERS
Community
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 66
Insgesamt: 710
