Zum Hauptinhalt wechseln
KidzLane Walkie-Talkie Press-to-speak button Replacement
Was du brauchst
  1. KidzLane Walkie-Talkie Press-to-speak button Replacement, Press-to-speak button: Schritt 1, Bild 1 von 1
    • Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
    • Flip the device over to where you see four screws in each corner.
    • Make sure you take out the batteries before proceeding.
  2. KidzLane Walkie-Talkie Press-to-speak button Replacement: Schritt 2, Bild 1 von 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: Schritt 2, Bild 2 von 2
    • Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
  3. KidzLane Walkie-Talkie Press-to-speak button Replacement: Schritt 3, Bild 1 von 1
    • Once you have unscrewed all four corners, open the device so it will be in two parts.
    • As you're opening the inside of the Walkie-Talkie, don't break off any wires within the device.
    • Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
    • Separate these screws from the other four since they are different sizes.
  4. KidzLane Walkie-Talkie Press-to-speak button Replacement: Schritt 4, Bild 1 von 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: Schritt 4, Bild 2 von 2
    • Take the circuit board out of the plastic casing.
    • Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Amin
642 Reputation
5 Anleitungen geschrieben
IUPUI, Team 1-1, Wilson Spring 2016 Mitglied von IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 994
