Einleitung
You will need a small Phillips head screwdriver and a soldering device to complete this project.
Was du brauchst
Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
Flip the device over to where you see four screws in each corner.
Make sure you take out the batteries before proceeding.
Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
Once you have unscrewed all four corners, open the device so it will be in two parts.
Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
Take the circuit board out of the plastic casing.
Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
