Einleitung
You will need to use solder device in order to be able to replace the power button.
Was du brauchst
Slowly separate the cases of the device. Try not to damage the wires connecting the two pieces.
Keep the two pieces away from each other so you can follow the next step accordingly.
Use the soldering iron to remove the broken switch.
Push down on the metal locks to separate the switch from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
