Einleitung
This guide covers the basic steps to replace the page turner keys on the First Generation Amazon Kindle.
Ersatzteile
Kein Ersatzteil erforderlich.
Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
Unplug the battery from the device by pinching the white connector and pulling.
Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
Carefully lift the SD Card Reader vertically from the motherboard.
Remove the two (2) Phillips #00 screws (3 mm) connecting the ON/OFF Power and Wifi Switches.
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
Carefully lift the ON/OFF Power and Wifi Switches vertically from the device motherboard.
Use a spudger to remove the Wifi antenna from the device by carefully prying it up off the casing.
Unscrew the two (2) Phillips #00 screws (3 mm) attaching the scroll bar.
Use a spudger to lift the flap vertically in the second image to release the scroll bar from the motherboard.
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the spudger.
Lift the flap with the pointed-end of the spudger to detach the ribbon cable indicated in the second image.
Use tweezers to pull the ribbon cable in the third image laterally to detach it.
Detach the cable by pulling laterally with tweezers or your fingertips. Do this by grasping the edges of the white connector and pulling laterally.
Grasp the end of the cable with tweezers or your fingertips and pull upwards to detach it from the motherboard.
Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
Carefully lift the motherboard off.
The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
Press down firmly on the two white tabs, behind the large 'NEXT PAGE' button with the spudger. This will unsnap the front casing from the rest of the device.
Slide out the large 'NEXT PAGE' button laterally away from the keyboard.
Slightly lift the top corner of the panel.
Slide the 'PREV PAGE' button out laterally towards the top corner.
