Einleitung
Archived/legacy version of the student-created keyboard guide.
Was du brauchst
Insert a plastic opening tool into the seam between the back and front of the Kindle 3 (as indicated in the photograph).
Using the plastic opening tool, lift the back cover of the device.
Remove the back cover.
Using a Phillips #00 screwdriver, remove the 14 silver screws (4mm) that secure the components within the housing.
Using the screwdriver, remove the 11 gray screws (4mm) that secure the motherboard to the housing.
Using the plastic opening tool, carefully lift the ribbon cable to disconnect it from the motherboard.
Latches secure the three remaining ribbon cables to the motherboard.
To disconnect the latched ribbon cable, open the latch and gently slide out the cable.
Insert the plastic opening tool underneath the silver-headed black cable and gently disconnect the cable from the motherboard.
