Einleitung
Having battery issues that require replacement? Well you're in the right place. You're also in luck: the battery is the easiest internal component of the Kindle 7th generation to replace. Follow this guide and your Kindle should be working in no time.
Was du brauchst
At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
Run the tool along the seams to pry open the front panel.
Peel the front panel off to remove it from the Kindle.
To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
Working evenly along the corners and edges, separate the internal contents from the back panel.
Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
Gently slide the cord from the motherboard connection.
Use the plastic opening tool to pry the battery from the backside of the screen.
Set the battery aside.
26 weitere Personen haben diese Anleitung absolviert.
17 Kommentare
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Where do I get a new battery from please?
You can get the batteries on Ebay.
