Einleitung
本指南帮助你更换Amazon Kindle Fire的电池。
Was du brauchst
在Kindle Fire右下角处楔一个塑料打开工具。
撬开外壳,沿着Kindle Fire的周围撬动塑料开口工具,释放夹子,使两个外壳相互分离。
从顶部撬开Kindle Fire的底部(从侧面)是有帮助的。 使用蛮力可能会导致内部的标签破裂。
重新组装您的设备时,请按照相反的顺序执行这些指示。
80 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
12 Kommentare
I'm usually intimidated by electronics when it comes time to pull off the back or something, so this guide was invaluable in my efforts to replace the battery. I found a great price ($28) on a replacement Kindle battery here: http://www.primelec.com/atl-tablet-eread...
Thanks again
great post, I came across http://bestbattery.biz/Amazon/189882-D01...
The batteries from bestbattery.biz tried and tested with us.
Used this guide to replace my battery. Sadly, it didn't fix the problem. The problem is with my charger connection. It is loose. I had hoped changing the battery and looking at the problem from the inside would resolve it. The charging connection is in it's own little housing. I considered opening the housing but I had no replacement parts to fix whatever may be wrong. I greatly appreciate the quality of this repair guide. There were no problems with tear down or putting back together. Thanks again!
Some kindles have a battery connection that "floats". The problem can be alleviated by soldering the charging port. There is an excellent video on YouTube that shows step by step, the process for soldering the charging port. Hope this helps!!!
Kindle Fire will not charge and when I wiggle the cord to charge the Kindle the light comes on but doesn't stay on. Tried a different cord still does not work. Where can I get another battery for the Kindle Fire. Please let me know or any Barnes and Noble bookstore or Staples, or Office Depot store where I can find a battery. Thanks Melony
