Zum Hauptinhalt wechseln
Kindle Fire 1st Generation Motherboard Replacement
Was du brauchst
  1. Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: Schritt 1, Bild 1 von 2 Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: Schritt 1, Bild 2 von 2
    • May need to use something to pry it open such as a screwdriver.
    • After you pop some of the little clips inside, you can use your fingers to remove it completely.
  2. Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: Schritt 2, Bild 1 von 3 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: Schritt 2, Bild 2 von 3 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: Schritt 2, Bild 3 von 3
    • The first photo shows two red circles over the screw that will need to be removed first.
    • After lifting the tab as shown in the third photo you will need the part number located below bar code.
  3. Kindle Fire 1st Generation Motherboard Replacement, Remove All Tabs: Schritt 3, Bild 1 von 1
    • Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
  4. Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: Schritt 4, Bild 1 von 3 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: Schritt 4, Bild 2 von 3 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: Schritt 4, Bild 3 von 3
    • Remove all of the wires that trace to the mother board.
    • Two speaker wires
    • Wire for battery
  5. Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: Schritt 5, Bild 1 von 3 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: Schritt 5, Bild 2 von 3 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: Schritt 5, Bild 3 von 3
    • Using your fillips screwdriver, remove the screws that have red circles around them.
    • The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed.
    • In addition, use your fingers to remove the tab that has a purple square around it.
  6. Kindle Fire 1st Generation Motherboard Replacement, Pull The Mother Board Out: Schritt 6, Bild 1 von 1
    • Pull the motherboard out and order the part.
Abschluss
Reed
133 Reputation
1 Anleitung geschrieben
Vegas Room H9 Mitglied von Vegas Room H9
Community
13 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 407
