Was du brauchst
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Lift up until you hear a slight popping noise.
Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
If your device has copper tape attached to the battery, carefully peel it off the battery.
Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
Lift and pull up the antenna connector and the antenna cable that surrounds the battery
Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
Lift the battery out of the device with your finger or the plastic opening tool.
Use the plastic opening tool to carefully lift the camera up.
Now you may lift the camera out of your device.
2 weitere Personen haben diese Anleitung absolviert.
